Post by persimmonpal on Mar 23, 2012 19:11:09 GMT -5
Post by harrison429 on Mar 24, 2012 4:37:52 GMT -5
I didn't know you could do it at home...make sure to take before and after pix so we can ooh and aah over your great results!
Post by universalexports on Mar 24, 2012 7:57:13 GMT -5
I wonder can you polish nickel to get it a a bit shinier?
Post by persimmonpal on Mar 24, 2012 8:15:07 GMT -5
Maybe a few more coats, and really buff it? Who knows?? I think its worth a try... I have everything I need except for the main ingredient ;D I figure its worth a try.. When I get some nickel oxide I will report back.. hopefully it will be decent enough.. I do think the lighting in the videos wasn't the greatest, so it may actually look better than pictured..
Post by ronaldjohn on Jul 23, 2012 14:19:32 GMT -5
Hello, that is an interesting question. Chrome plating is done by preparing significant amounts of sulfuric acid unto large beaker with two electrodes submerged. This in turn will hold wiring connected to power source or battery serving as anode and cathode. The chemical process transfers the coating to the metal to be plated. ventilation equipment manufacturers
