Wiring
Apr 10, 2012 20:15:02 GMT -5
Post by capper on Apr 10, 2012 20:15:02 GMT -5
Wiring trailer plug i have green brown red yellow and black powder explain what goes where thanks capper.
Wiring
Apr 11, 2012 1:29:02 GMT -5
Post by vikx on Apr 11, 2012 1:29:02 GMT -5
The 7 way plug is what you should use. The colors are stamped in the plastic of the plug.:
Black=hot White=Ground Red=Left Turn Brown=Right Turn Green=Running Lights. Yellow is an aux wire, often used for backup lights in newer trailers.
BUT: you must test the wires on your trailer to discover what they are really for. Use a 12 volt battery. Ground to the trailer frame and carefully touch each wire to the hot side. Label each wire according to what it does.
