Post by cmaddox30 on Oct 19, 2012 0:15:54 GMT -5
Hello. This is my second post/question. I was lucky enough to find a 1972 loflyte The previous owner has ruined the first section of a triple window in the dinette, kitchen area on the side of the trailer by destroying it and putting an A/C home sized window unit in . I have torn it out, and the main aluminum frame is bent but in tact. Can anyone tell me what the best method of creating a window to replace the ac unit? I know it wont be original, or match the factory aluminum trim...but i dont want to put another window unit it. suggestions please!! thank you.
Post by pathfinder3081 on Oct 19, 2012 8:02:40 GMT -5
Take a snapshot there brother and give us a feel for what your dealing with. We can come up with something.. or point you to those who can.. I am sure of it.
Post by dawgpound on Oct 19, 2012 17:05:00 GMT -5
If you can take a picture of the window and the missing jalousie section. Give me the measurements of the opposite side jalousie window frames.
I have several windows that can be disassembled and refit to your window, provided that I have the correct size.
I had the same issue with the center solid pane that should have been in the front window of our '70 Starflyte. The PO added an AC Unit in it's place. I had a perfect size jalousie window and turned the opening into an operational window.
Anything is possible if you can get hold of the right parts.
Post by cmaddox30 on Oct 26, 2012 14:16:37 GMT -5
Hi guys! thanks for the input. Sorry it took so long to respond, i couldnt get over to take a pic. the type of replacement window doesnt really matter so much, so if its a Jalousie or not. thanks for your help. Attachments:
Post by cmaddox30 on Oct 26, 2012 14:24:00 GMT -5
I am not sure how to measure for the correct size, can you give me some guidance?
Post by Deleted on Oct 26, 2012 18:20:35 GMT -5
Measure the rough opening that you have with the window missing, then measure the opposite awning window that is intact. L X W to the edges of the frame is how I usually do it....I could be wrong.
Post by pathfinder3081 on Oct 26, 2012 20:05:51 GMT -5
Mmmm.. I m', with Chris on the checking the opposite side. But ya know? I am in the process of changing out a small window at bunk level in my girl. Seems nobody has one, so I figured I would start taking apart some of the windows that I scraped from a Compact in Charlotte. These things are mass produced with the same horiz rails and verticals. You can scrap one and stick build one smaller. I think that you should pull the whole frame out. It is a one piece unit. Take some rails from another, create your bottom rail and work it all together again. Once you get it on a table brother it's really not that bad at all. Even the glass and there frames as well Now, with out posting alot of the stuff that I am pulling together, here is one that I pull from that Compact. The thing is put together with a few screws and some snap rings. These things are "Cookie Cutters" and fabricated to the space required.. good luck. and when you get closer to knowings what you need.. length wise let me know. I think that this one is too square for your rectangular profile. Attachments:
Post by dawgpound on Oct 29, 2012 9:35:59 GMT -5
For finding the correct size jalousie window pane frames for your Shasta, simply measure the opposite 2 pane frames. They should be the exact same size. It will be easier to measure if you open the window.
Example: 8" x 27" each
Post by cmaddox30 on Oct 29, 2012 14:55:04 GMT -5
ok thanks again for helping me out.
So I have measured the existing jalousie window and the measurement is (from edge of aluminum trim): 23.5W x 14H
Post by dawgpound on Oct 30, 2012 7:54:25 GMT -5
It would be easier to find a match if you were to measure the 2 actual jalousie window pane frames.
You have only 2 panes that you need to find and they should be the exact same size as the opposite side, correct?
Just open that side and measure the actual window pane frames, not the entire overall size. Each window pane frame should be about 7" high and the length of each should about 22".
Ross
