Post by universalexports on Oct 23, 2012 19:43:12 GMT -5
just thinking ahead, I am putting a bathroom in my Shasta airflyte and givin that it is small and enclosed I tend to think a vented bathroom might not be a bad idea.
issues, not happy with the idea of cutting a hole in the roof, but I might. I might be able to figure out how to mount it in the rear window that will be in the bathroom, but then the window would have to open, so that is probably not a good idea.
do they even make a small roof vent for something like that?
Post by universalexports on Oct 23, 2012 19:52:02 GMT -5
I just had a brainstorm, I might be able to put a vent that exited the camper behind the wing??? better than cutting a hole in the roof, and the hole in the side would be behind the wing. something like a small 4 inch fan.
Post by kto17 on Oct 23, 2012 21:02:44 GMT -5
Is there enough space on the side wall to do a small tilt out like the Deluxe has in the bathroom? You could get one from the Cutters.
Post by universalexports on Oct 23, 2012 21:09:03 GMT -5
do you mean like the small window in this pic, (ignore the red circle) that might work, but is would not have a fan to push the smell out. guess it would eventually air out.
Post by kto17 on Oct 23, 2012 23:52:43 GMT -5
Yep. That's the one. I'm sure you could set up a 12v powered small fan like a pc cooling fan to better circulate the air. You could even use two and one blowing in and one blowing out. You could make it so they hang on the inside of the window and you can take them down when not needed.
I plan to do something like that for our Deluxe.
