mikel
Post by mikel on Dec 19, 2012 23:56:28 GMT -5
Hi, Today I bought a '63 Airflyte with the exterior in very good shape with the exceptions of forward and rear window leaks and almost no paint left at all. My question is I'll be painting her soon, but wanted to know if I should replace and re seal the windows which appear to be leaking first, and if so, I'd like to replace the rusted screws throughout. From reading earlier posts, it sounds like stainless is the rout to go, but what size screws will I need? Thanks.
Post by cowcharge on Dec 20, 2012 2:25:36 GMT -5
Well first off, as long as you're taking the windows out, technically speaking (anally speaking) it's better to paint the skin with them still out, since there won't be any skin hidden behind window frames, so you won't leave a messy "joint" in the paint and an inch of unpainted skin. As for the screws, if the wood, and the old screw holes, are in good shape you can use the same size as the old ones, what are they, #6 (I don't know if all campers used the same size originally or not)? But if you want more "bite" in the wood, you can go up a size to a #8, or up to a #10 if the old ones were #8. If you don't know the old size, just bring one to the store with you to compare and buy the same size or bigger as the case requires.
Post by Deleted on Dec 20, 2012 7:30:06 GMT -5
One thing always leads to another.
Post by schweetcruisers on Dec 20, 2012 11:53:20 GMT -5
The standard size is #6 x 3/4" stainless steel screws. A lot of us have bypassed the big box store and order them online, I personally found them the cheapest at Boltdepot, here is the link for the screws, www.boltdepot.com/Sheet_metal_screws_Phillips_pan_head_Stainless_steel_18-8_6.aspxI recommend ordering a lot, I ordered a bag of 1000. You will find that stainless steel is soft, you will strip some of the heads and some will break, plus you'll want to start replacing other screws, as Chris said "one thing leads to another!"
Post by Deleted on Dec 20, 2012 13:00:51 GMT -5
Only 1000 Schweet? There are that many around the dinette window.
Post by schweetcruisers on Dec 20, 2012 13:23:29 GMT -5
Only 1000 Schweet? There are that man around the dinette window. I was pretty surprised by not how many screws I used but how many nails. I ordered a box of 750 and I have less than 20 left!
