Post by schweetcruisers on Dec 27, 2012 23:22:50 GMT -5
I am hoping to inconvince a member (Chris, Universal), I need pics of the entrance door header, esp the aluminum trim, is it the same as the threshold? Again mine was missing.
Thanks
Post by vikx on Dec 28, 2012 1:54:25 GMT -5
Usually, the door trim at the top is just a right angle, longer on one side. It is the same as both side pieces and often a little different than the bottom. (bottom has an extra lip to prevent leakage) Attachments:
Post by Deleted on Dec 28, 2012 9:56:41 GMT -5
Here ya go, Schweet. This is the top corner on the latch side of the frame. I thought I had this taken the other day but couldn't find this view. So these are hot off the press this morning. The trim is about 1-5/8 inches wide. It does not cover the entire wood frame.
Post by Deleted on Dec 28, 2012 9:57:20 GMT -5
Upper outside door removed.
Post by Deleted on Dec 28, 2012 10:01:31 GMT -5
Hinge side. The lip over the siding is about 1/2 inch, where the lip of the side trim pieces are a little bit wider, about 5/8 or so. Attachments:
Post by universalexports on Dec 28, 2012 11:00:11 GMT -5
Sorry, I am at work and cant post any pics, but I am 99% sure mine is just like the one above, I recently replaced the wood above mine and that looks the same.
it seem to really have only one function and that was to hold the outer skin above the door to the frame.
Post by schweetcruisers on Dec 28, 2012 17:47:03 GMT -5
Thanks Everyone, Chris it looks like there is a lip that hangs down into the door opening, any idea what the purpose of that is?
Post by universalexports on Dec 28, 2012 18:01:37 GMT -5
Hinge side. The lip over the siding is about 1/2 inch, where the lip of the side trim pieces are a little bit wider, about 5/8 or so. mine is just like this, no lip hanging down in the opening, click on the pic above to make it bigger.
Post by schweetcruisers on Dec 28, 2012 18:17:03 GMT -5
Hinge side. The lip over the siding is about 1/2 inch, where the lip of the side trim pieces are a little bit wider, about 5/8 or so. mine is just like this, no lip hanging down in the opening, click on the pic above to make it bigger. Is this a optical illusion? Is that the drip cap making it look like a lip? Thanks
Post by Deleted on Dec 28, 2012 22:14:43 GMT -5
Not the best photo I guess, this is another angle. The piece appears like a right angle bend on a flat sheet, with a doubling up of the outer edge over the siding.
