Post by paigenmarc on Mar 12, 2013 14:09:09 GMT -5
I am missing the crossrails for my trailer window. Not sure what the technical term is, but it's the horizontal track the notched piece slides in to open the window. Can this be replaced? Anyone have these? Attachments:
znorm
Post by znorm on Mar 12, 2013 14:23:07 GMT -5
You can have them made by a sheet metal shop. That is what I did. I will take a picture of the old ones and the new. I think you have the same window as I do. Mine is from a 64' Airflyte. window size approx. 34"x14". Send me a PM so I dont forget.
znorm
Post by znorm on Mar 12, 2013 14:27:53 GMT -5
Are you missing both pieces? Is it just the pieces in the window frame itself? The pieces in the main frame itself is a little complicated with a slide spring that keeps the notch arms steady and helps lock into place.
Post by paigenmarc on Mar 12, 2013 16:08:42 GMT -5
We have this part Attachments:
Post by paigenmarc on Mar 12, 2013 16:09:19 GMT -5
We need this part - the part going across Attachments:
Post by schweetcruisers on Mar 12, 2013 22:41:53 GMT -5
I know you probably don't want to spend the money and believe me I understand, but Vintagecampers.com has a few complete window units for sale on their parts store. You might also might get lucky and they might just have the bar, they've seem to have a lot parts from windows they parted out, I'd call them and check! Good luck!
Post by paigenmarc on Mar 19, 2013 19:08:15 GMT -5
I didn't find any. Let me know how it goes!
znorm
Post by znorm on Mar 20, 2013 23:13:16 GMT -5
The reason why these break is because where the notched arm is rubbing at the fastening point. It needs to be ground down where it is bolted. It needs to be a smooth radius. Take a close look at it and you will see why it is breaking.
Post by Deleted on Mar 22, 2013 13:37:36 GMT -5
Hey Lovn, if you could, would you post a couple photos of the process, or at least the finished product? I have the same problem I will have to address eventually.
Post by lovnvintage on Mar 22, 2013 14:34:36 GMT -5
The old end Attachments:
Post by lovnvintage on Mar 22, 2013 14:35:35 GMT -5
new end, it isn't purty but will work for now Attachments:
Post by lovnvintage on Mar 22, 2013 14:38:48 GMT -5
new completed pc. I took the old one to h.depot to match size and it was almost exact. Attachments:
Post by Deleted on Mar 22, 2013 20:29:12 GMT -5
Hey, it may not be pretty but if it works, it is lots better than the old and broken, right? I have one that is snapped and the lever is missing, and the other is about to break at the hings, and the second lever is broken off at about 3 inches. Not much to model from. Thank you for the photos. This really helps.
Post by mobiltec on Mar 25, 2013 11:49:05 GMT -5
